Results 1 to 12 of 12
    Non-member bernard's Avatar
    Devon
    moving header tank
    Would anyone mind showing me how they went about moving the header tank into the bulkhead, I would like to move it so I can gain room to put my air filter behind the headlight and also box it off and maybe have a small scoop on the bonnet if I can find one that looks suitable.thanks
    Devon
    Re: moving header tank
    bump
    Feb 2009
    Walsall
    would love to help mate.. been seeing your thread blank for few days now.
    stil waiting to get my 5. ima do it to mine thou wen i get it so if anyone replys ima have a look aswel!
    Non-member tiff_lee's Avatar
    Glasgow/Lincs
    I'm in the process of doing the same thing, got some sheet aluminium to box off behind the RH headlight and have moved the header tank to the drivers side behind the firewall.
    Going to drill some large holes in the firewall for silicone hoses and use large wiring grommets so the hoses don't catch on the holes.
    Devon
    cheers chaps, I was just after seeing some pictures to see how others have done it really, I may not bother now and just move the header tank to where the air filter is, Ive ordered some 2mm carbon fibre to box it of and also a carbon vent.
    Non-member 5teve L's Avatar
    RH12
    Sam, PM James, he had it done on his GTT with the C1J in... & has piccies...
    HTH
    Steve
    Devon
    HTH
    Steve
    o cool I shall ask him, with that block of yours did it ever smoke a litte now and again or get a whiff of oil, it just happens now and again thats all. cheers
    RH12
    Quote Originally Posted by bernard View Post
    No mate, never.. only thing i had with it was an oil leak on the timing chain where i took it off to look at the timing & it didn't seal up fully (coz it's bloody awkward to do in the car)
    Devon
    orite well im not going to worry about it, I cant get anuf of the car at the mo I keep driving it to work cant help it when Ive got my work car also which is a boring vectra. I also had a oil leak from the timing chain cover sorted that now Ive got a small leak from the sump .
    RH12
    I did tell you to slap a load of sealant on both before you fitted the engine to the car
    I miss my 5
    HTH
    Steve
    Couple of pics of the header tank in the anti perc fan location where I had it
    Devon
    cheers james, never thought of putting it there.
