Ok just checking is the gt turbo Fuel filter metal with 2x threaded connections, 1 of either end.
Fuel filter shouldn't have threaded ends on it, the hoess just push on over them and not thread on.
ahh **** i thought that was possibly the case mark , it appears the boffins at motormania supplied me the wrong one gayy
where do most folks buy there fuel filter from ? as its the second incorrect filter now
ph1's are clear plastic, mine had a metal coke can one on, was bigger than the one listed for my car and eventually found its the same as a mk2 golf 1.8 gti?!?
i allways buy genuine fuel filters but you can get the from most motor factors cud try cgb or gsf renualt supply me with a plastic filter but u can get a metal 1
http://www.gt-turbo-spares.co.uk/ind...age&prod_id=46
They have changed from the metal ones to plastics ones now, different manufacture, but work just as well and they will not rust.
