Results 1 to 12 of 12
    Non-member Rusty's Avatar
    Edinburgh, Scotland
    Fitting Cam
    I'm considering fitting a piper cam in my 5 and acknowledge that removal of the engine is required. But is it possible to fit the cam with the engine in?
    Dec 2004
    Aylesbury
    Re: Fitting Cam
    Yes it is possible but you will need to tilt the engine over so the cam can be pulled out of the block and rest in the hole in the inner wing (where perc fan lives) and be pull from the car. Its abit fiddly and to be honest might be easy enough to just pull the engine out, there is a way of doing it with the head on too but honestly prob easier to pull head off and then pull block out of the car.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Fitting Cam
    leave the engine in, it's actually pretty easy. cylinder head off, remove perc fan and other bits and bobs in the front driver side of the bay then remove front driver side engine mount nut from underside of subframe and jack the engine up via the sump. you can get the engine up high enough so that the cam comes out and straight into the big round hole in the inner wing where the perc fan normally lives. jacking the engine also improves access to the timing cover, pulley etc.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Fitting Cam
    too slow
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Re: Fitting Cam
    yes indeed.
    you need to remove the head.
    undo the engine mount below the alternator.
    remove the perc fan if you have one.
    obviously remove the sump+timing covers.
    now jack the engine up until you cam is level with the perc fan hole on the inner wing.[engine will tilt up higher on the waterpump side]
    pull the cam out, the percfan hole give you that extra clearence you need to remove the cam with the engine still in.
    tiz what scoff told me and it works.
    Dec 2004
    Aylesbury
    Re: Fitting Cam
    too slow
    Just beat you
    Loose Bolts Tuning stuTHC's Avatar
    Dec 2005
    Leeds
    Re: Fitting Cam
    Just beat you
    and raj was a respectable 3rd
    Feb 2001
    Rohtang pass
    Re: Fitting Cam
    Quote Originally Posted by stuTHC View Post
    lol, RIGHT! im telling my mummy and she will slap the face off your heads
    Edinburgh, Scotland
    Re: Fitting Cam
    Many thanks guys, i need to do my headgasket and engine mounts so that should work out nicely . I don't have an perc fan either. It sounds relatively easy but i know from experience that it'll will turn into a nightmare . Thanks for your advice, i'll give it a bash and let you know how it goes.
    Non-member Theros's Avatar
    Tampere / Finland
    Re: Fitting Cam
    Is it possible to change cam if head is not removed and engine is not in the car? Of course push rods need to be removed (I try to change uprated valve springs bymyself...any tips to do that? I don't have specific device to compress springs.)
    Tipton
    Re: Fitting Cam
    you can pull the cam followers into the space between the block and the head, using a magnetic pen.
    you can then take the dizzy gear out.
    and then the cam can come out.
    to put the folowers back in use a screwdriver - tilt the folower forward and push it back into the hole.
    as done by me...today.
    Non-member Adam 005's Avatar
    Dorset
    Re: Fitting Cam
    did my cam with head still on but engine was out at the time so not to hard to be fair
