fuel pump relay location?
Where is the fuel pump relay located on a 5?
A mate has asked me can i get him a pump but i said i will check his relay is working 1st, so i dont want to go round to his and spend time searching for the relay.
Re: fuel pump relay location?
Hi, it is up behind the fuse box, if it is still in it orginal location it will be atteched by a screw to the right hand side of the fue box as you look at it.
Where is the fusebox?
Is it under the glovebox like on my 11?
Passenger's side under the glove box.
