Results 1 to 29 of 29
    burton on trent
    ford ka tappets
    I need to set the tappets on the gfs ka, i have a set of feeler gauges, but i have no idea how to do them, anybody care to explain ?
    Re: ford ka tappets
    What age is the KA? Has it got the Zetec engine in or the fail safe push rod?
    Trader paul b's Avatar
    Jul 2002
    Re: ford ka tappets
    only ever seen hydraulic lifters on them....non adjustable.
    what year, engine is it....?????
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: ford ka tappets
    all ka's i have ever known all get tappy with age. have cured a few though with a good oil change.
    Re: ford ka tappets
    I thought the older type engine i.e. the ones found in the old MK2 fiesta were adjustable?
    Dec 2004
    Aylesbury
    Re: ford ka tappets
    They are, if its a small engined early Ka it'll be the old pushrod engine in there.
    Non-member car.crash's Avatar
    Aug 2006
    Re: ford ka tappets
    the early 1.3 endura pushrod engine has adjustable tappets
    the later 1.2 and 1.4 zetec is hydraulic.
    burton on trent
    Re: ford ka tappets
    yea its the 1,3 engine so push rod and adjustable tappets
    Aug 2006
    Non-member scratcher's Avatar
    Milton Keynes - ish
    Re: ford ka tappets
    The later KA's are 1.3 8v Duratec, or 1.6 in the Sport or Street ones.
    Aug 2006
    Re: ford ka tappets
    ooops sorry, my error
    Milton Keynes - ish
    Re: ford ka tappets
    Haha, I'm a bit of a geek with the girly cars
    burton on trent
    Re: ford ka tappets
    Well i found this snippet of info,
    'The inlet valve clearance should be set to be 0·20mm and the exhaust valve to be 0·50mm (with the exception of some of the very early Endura-E, which has an exhaust valve clearance of 0·30mm).'
    however ive never set tappets before, not a clue wont you rock the car and crazy stuff :s
    Jan 2004
    BEDFORD
    Re: ford ka tappets
    http://cgi.ebay.co.uk/Haynes-manual-...1%7C240%3A1318
    i think its time to invest
    burton on trent
    Re: ford ka tappets
    haha , yes maybe man, to be honest though its just a damn work horse, n i said from the beginning i didnt wana have to work on it at all ah well .. grr fords! rusty noisy slow grr
    Re: ford ka tappets
    The principal for setting tappets is the same for any engine, if you've got a haynes for the 5 use that principal but for the correct distances
    burton on trent
    Re: ford ka tappets
    Thank you ill look at doing it this weekend.
    burton on trent
    Re: ford ka tappets
    ok i have just been reading on doing this in my r5 haynes manual..
    only thing im unsure of is, that you have 8 valves, starting at the flywheel (right hand side) and the closest to the flywheel is no1 Exhaust valve, and im guessing next to that is no2 Inlet Valve , and so on, is this correct ? and is it always the same on all engines in the fact that the first is the eghaust and the 2nd is the inlet.
    Only other thing is that my feeler gauges only go up to 0.30 :S, should i hold the 0.20 and the 0.30 together to give me the 0.50 measurement required for the exhaust measurement
    Non-member Ben's Avatar
    Ruislip
    Re: ford ka tappets
    Think it goes exhaust, inlet ,exhaust, inlet, inlet, exhaust, inlet exhaust.
    burton on trent
    Re: ford ka tappets
    ah damn, now thts baffled me :P
    Ruislip
    Re: ford ka tappets
    The centre two are the both inlets because if it was exhaust, inlet all the way it would be inbalanced. e.g. you would have an exhaust valve at the flywheel end and an inlet at the timing chain end.
    burton on trent
    Re: ford ka tappets
    ahh i see i see, is that goings to be the same then for all 8 valve cars
    Ruislip
    Re: ford ka tappets
    yes 99.99999%, bound to be some nutter out there whose made an engine differently. and the leyland a series engine is not quite the same as it uses a common port system where 2 inlets are fed from the same intake.
    Trader
    Big Jim Racing
    Chadwell Heath, Essex
    Re: ford ka tappets
    If I remember rightly the endura lump doesn't pair the valves, its in ex in ex all the way(or vice-versa). Anyway, just look at the casting, you'll be able to see which port goes to which valve.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: ford ka tappets
    Quote Originally Posted by Big Jim Racing View Post
    yeah, I remember experimenting with 120ron prostock fuel with 9.2:1 c/r and a lot of boost, it worked ok. in later years I found the type of fuel to be more important than I first thought, the prostock was pretty horrid stuff, using a good octane boost in pump fuel worked a lot better. the prostock felt really flat off boost, the octane booster was not noticible other than for it supressing det and worked much better.
    Trader
    Big Jim Racing
    Re: ford ka tappets
    Are you sure that's the right reply...
    The trouble with high lead fuels like that is they burn REALLY slowly and they aren't really meant to do much other than have huge det resistance, so, as I'm sure you found, they don't start well either. 9.2 wouldn't have been working it nearly hard enough to be worthwhile (unless you were running about 50psi+), I wasn't exaggerating with the 11:1 comment. Not sure how the engine would take it (mechanically) though!!!
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: ford ka tappets
    Whoops, I ment to quote your post in the other thread, its been a long day
    Dublin/Ireland
    Re: ford ka tappets
    ur also better off with a tapered set of feeler blades as for the gt because of wear! a broad type wont let u adjust it right.those particular engines are very rattely anyway.
    Ruislip
    Re: ford ka tappets
    Yea your right m8 forgot its a crossflow thinking of the old kent engine before it went xflow.just me typing before thinking and sorry for confusing ya
