Results 1 to 2 of 2
    Hackney
    Sudden idling/running issue.
    Hello, another question! Sorry!
    The 11 suddenly developed this running / idling issue I'm starting to run out of ideas.
    It was idling perfectly and then stalled.Since then it will not idle below 1200rpm and hunts baldly,I held it at a steady 3000 yesterday and the misfire was still there.
    It's had :
    New manifold gasket,
    New fuel pump +filter
    New plugs
    New Dizzy cap
    Leads are good
    Fresh fuel
    Compression test (all cylinders at 11 bar!)
    Finally a carb rebuild which made absolutely no difference! I've rechecked & blown through the idle jet which also has a new o ring.
    Also popped a new coil on as I had one.
    I haven't checked the Co at idle or fuel pressure at carb, but wondered whether the Fuel pressure reg could be the culprit? £50 for a ropy looking used one seems a lot to me..
    Any thoughts would be bloody brilliant!
    Thanks again ��
    Re: Sudden idling/running issue.
    Replied on other thread.
