Results 1 to 4 of 4
    Dec 2013
    Fuel problem
    Hi all I am hoping someone could help me.
    I was driving to work in the morning in my renault 5 turbo chugging along nicely at about 40 mph when all of a sudden my car decided it didn't want to finish the journey (typical 5) and cut out in the middle of a busy main road. I tried to start the car but it wouldn't fire. My first thought was fuel pump. I got the car home and decided to take the pump out and hook it up to 12 volts and it fired up. So I thought fuel pump relay I checked the power to the pump with a volt meter and no power. I got a new fuel relay put it in the car and nothing. I checked the fuel lines to the motor and nothing.
    Has any one any ideas what it could be ??????
    Re: Fuel problem
    TDC sensor/lead
    No pulse signal, No fuel! its located ontop of the gear box and the lead is in two bits with a connector in the middle. Follow it to the AEI module.
    Likes Ian S liked this post
    Re: Fuel problem
    Or AEI relay.
    Likes Matt Cole liked this post
    Non-member Stylin_ju's Avatar
    Mar 2016
    Re: Fuel problem
    Did you check your car grounds?
    It happened to me few year ago, I stopped at a stop and engine stopped as well.... I was lucky it happened behind home.
    I spent 2/3 weeks, changing fuel pump, relay until changing spark plugs etc....
    I cleaned and grease my grounds and it's running fine since then!
    They're located:
    - one under the left headlamp when you're in the front of the car,
    - one when you remove the rear light left cluster when face the back of it
    - 2 under dashboard on each side
    Please bear in mind that my car is a LHD, so It might be reversed (not for the dashboard though)
    Then one at the battery ground to chassis and same point at the chassis to engine.
    My 928 is a RHD and I had to remove the opposite panels to "seek and destroy" gremlins!
    Good luck
