Results 1 to 10 of 10
    Non-member Mad_Mat's Avatar
    Jul 2015
    5 gtt setup check Hertfordshire area?
    So just bought a 5 GTT and need a setup check. Fueling Boost etc. Mostly standard spec wise.
    Who should I be talking to in the Herts Beds Bucks area that knows these cars and engines well?
    Thanks
    Re: 5 gtt setup check Hertfordshire area?
    Highly recommend Chris at efi parts www.efiparts.co.uk .Tell him rtoc have sent you. He has full rolling road set up. Also if it's a quick check and adjust, you could try Markey Mark. He's a member on here too. https://www.rtoc.org/boards/member.ph...rkey-Mark-(BD)
    Feb 2015
    Best way is to learn yourself. Plenty of articles on here and clued up members to help.
    Jul 2015
    Thanks for that. i have pinged Marky Mark a pm.
    Hopefully he will be able to cast an eye over it for me.
    Jul 2015
    Quote Originally Posted by francob80 View Post
    Totally agree. I am capable but this is my first 5 so wise to seek advice from those that have been there done it and got the T-Shirt.
    Feb 2015
    First bit of advice if you haven't already done so is purchase in AFR gauge as without it setting up fuelling will be complete guesswork.
    Apr 2014
    Mark Fish in Harlow?
    Likes Mad_Mat liked this post
    Jul 2015
    Been to see Marky Mark. Top fella quickly identified a breather issue allowing to much air through.
    Reset idle mixture and speed.
    Test drive revealed down on boost. Actuator looks old and the spring has gone weak.
    Will get a new actuator and go see Mark again and get setup to a 1bar.
    So big thanks to Mark.
    MM
    Likes Mr Raider liked this post
    Spot on mate. Worth the £15 membership already!
    Norwich
    Great to here fella, thats what the rtoc is all about.
