Results 1 to 4 of 4
    Non-member Matthew Dyer's Avatar
    Torquay
    Breather pipe
    Can someone please tell me were the breather pipe that's on the back of turbo goes to picture would help
    thanks
    Re: Breather pipe
    Quote Originally Posted by Matthew Dyer View Post
    thanks
    You going back to standard pipes, if so you mean the metal one that comes out the std elbow? that gets T into the carb top. Personally don't bother and just block the rear of the elbow with a suitable size bolt
    Torquay
    Re: Breather pipe
    Thats grte rate thanks I did wonder if you could do that
    thanks 👍
    Non-member scratcher's Avatar
    Milton Keynes - ish
    Re: Breather pipe
    That pipe is part of the actuator system.
    As James said, you can plug it up.
    A wheel bolt fits just right I put one in, cut it flush and had it welded to seal it up.
    Likes James5 liked this post
