Results 1 to 23 of 23
    Feb 2012
    Oil pressure readings
    Does anyone know what psi we should be seeing from the oil pressure ? I'm getting a steady 33-35 psi from 2k up to 6k rpm .
    Re: Oil pressure readings
    I seem to recall:
    Cold: 3.5 to 6 Bar.
    Hot: 1 to 3.5 Bar.
    Perhaps someone with a more recent memory than mine can post something more accurate here.
    Norwich
    Just wondering are you taking oil pressure reading from aftermarket capillary gauge? oe dash gauges are not known for their accuracy.
    Also, worth bearing in mind what oil/filter you are using as this could possibly change oil pressure readings particularly when hot.
    It should be circa 40-45 psi when fully warmed up at 3k.
    Feb 2012
    yea its an after market digi dash, getting a reading of 30-35 psi.
    ive changed the oil pump and im thinking they could supplied me with a non turbo pump. Does anyone have the renault part number for the oe pump for a turbo model?
    using 10w 40's morrisons oil with a fram oil filter.
    Non-member tubbyG's Avatar
    Dec 2010
    Where did you purchase the pump from? was it a complete unit or just part of it?
    Part number for a complete Oil pump can be found here: https://www.rtoc.org/boards/showthrea...il-Pump-Page-1
    Although I have no idea if they are still available - and will be pricey if they are!
    Recently I purchased a refurb kit for my oil pump
    http://www.ebay.co.uk/itm/RENAULT-5-...YAAOxypNtSenxi
    If it were me, before I got stuck into stripping down the bottom end - I would start by ditching that oil and use a recognised brand of oil then go from there.
    30psi to 35psi is too low! There are 2 different types of pumps a geared pump and a vane pump with pressure relief. The latter is the gt turbo one. Can you remember what the pump looked like?
    If the engine has a few miles on it, I would stick with a good quality semi synthetic such as Mobil super 2000 grade 10w 40
    Feb 2012
    Yea the engine is brand new i've just rebuilt it, ive just ordered a new oil pump (the last one in the country) i'll probably get a phone call in the morning saying they can't find it or something lol. Thanks for the part numbers above made life much easier!!
    The pump appeared to be the same as the Renault pump looks wise it was a completenew unit al-bett after market.
    The oil i have init is morris oil not morrisons.lol
    Norwich
    Hopefully the oil pump will come through from Renault, if not new internals are available from CGB Motorsport to rebuild R5GTT oil pumps.
    The digital oil pressure gauge must be electric and not capillary, not heard of Morris oil everyone has their own preference I used to recommend Millers semi synth. Good to hear there's a proper OE oil filter on there too, there was a lad on the Facebook group last night that had a massive Halfords oil filter 3 times the height of the Fram/Purflux, unfortunately his engine lasted 5 minutes with that on due to low oil pressure! lol
    Non-member Fordy's Avatar
    Aug 2010
    Cambridgeshire
    Renault had 9 new oil pumps in stock about a month or so ago. I brought 1 so there was 8 left.
    The clue was CGB's picture of a new oil pump clearly showed the date stamp on the casing as "2" so i asked my dealer and they had come back into stock
    The oil pumps have come down in price then as they were something daft like £500!! I hope Renault are providing the correct one for the GT?
    Aug 2010
    Cambridgeshire
    The price isn't high, Cgb just make it seem that way with their extortionate mark up then +vat
    Yes 100% genuine GT turbo oil pump, new lower, upper body's and internals, it's not exchange either
    Likes Matt Cole liked this post
    Feb 2012
    Quote Originally Posted by Fordy View Post
    £267 plus vat .. £348 retail plus vat
    Feb 2012
    well the new pump turned up today, it will be interesting to see what pressure this one reads. hopefully not 35psi . Along with one of scoffs afr gauges lm-3..
    Danny, take some picks so we can drool a new part.
    Feb 2012
    Sorry buddy it's on and sump back on , I haven't started it just to let the sealant go of over night, there was a visible difference with the pumps , I had a sharp word with our engine components supplier he's agreed to take the pump back and if needs be supply any damaged parts , but to be fair the sump was pretty clean with just a few small pieces of metal of which I'd expect from a new build engine .
    I will take some pictures of the car and post . Can they be uploaded via an iPhone to a thread ?
    Quote Originally Posted by Danny View Post
    Yes. Just make sure the pic sizes aren't too big.
    Feb 2012
    huge difference in pressure on idle when cold, 48 psi... just another learning curve never trust a parts man.......
    Norwich
    Whats the oil pressure in psi when upto temp or hot? When cold my capillary gauge reads 60psi on idle.
    Is that on a cold engine before been driven if so about normal??
    When hot and after a drive should be around 10-15psi on idle
    Its when the oil is hot that you really need to know.
    Feb 2012
    yes just took round the block after I'd passed it on the mot retest readings of 12psi at idle at oil temp of 55 deg coolant temp @ 85
    happy days ...
    See what it is with the oil temp at 70-80c
