Results 1 to 10 of 10
    Non-member Fordy's Avatar
    Aug 2010
    Cambridgeshire
    Camshafts, Piper 285 blank or Catcam 5500327
    So 4 years ago i built my engine and its undergoing a major rebuild, the more a strip the more i find worn or damaged,
    Crank pitted on main journals,
    1x Conrod bent
    3x Inlet valve collets cracked in half and valve grooves elongated
    Oil pump scored beyond believe was a refurb unit 4 years ago
    8x Cam followers pitted
    Camshaft pitted on lobes was reprofiled 4 years ago by piper 285
    So my rebuild so far includes
    New crank
    Forged 77m wossner pistons, pec rods
    Ductile liners
    Head modified bigger inlet 36mm and exhaust valves 32mm, 3 angle seats yada yada, head skimmed to 73mm
    Head CC'd at 41.5cc
    Compression ratio atm up around 8:5-1 (Megasquirt fitted so not worried)
    But with finding my cam pitted, I wonder if the 285 is really needed anymore?
    Looking through as much as i can wouldn't a 5500327 BB cam be better suited?
    My thoughts are, Bigger valves require less lift for same flow and I noticed the higher I rev'd up to 8000rpm at times the more often push rods got bent, got to admit flat shift was being used so probably didn't help kinder lobe ramp rates happier valvetrain
    SO
    CatCam "BB" 5500327 OR Piper 285 blank?
    Feb 2011
    Down South
    Re: Camshafts, Piper 285 blank or Catcam 5500327
    i highly recommend the bb cat cam our old c1j that i built has just made 220bhp with that cam and a t28 @21psi i sold the engine but everything was brand new std pustons but brand new this cam is slighty less lift than a 285 if you check the cam wizard, id rate it more than the 285 boss. it had more left too but was emptying the bowl pmsl
    Aug 2010
    Cambridgeshire
    I have been running 24-26psi with t28 and 285 before noticing my potential valve drop
    I seem to think the 285 is all peak hp and a small torque band
    Finding someone with experience of both cams is going to be a task
    Catcams are cheaper and much better customer service than piper from what ive found when asking about valve springs
    Stick with what I know or sell the piper springs and cam and try something new
    Feb 2011
    Down South
    im not saying it wont make more lol check the cam wizard and put the cams against each other
    https://rtoc.org/tech.php
    btw i ran piper springs with the bb cam it was fine boss
    Aug 2010
    Cambridgeshire
    Custom larger valves and titanium retainers means my piper springs just don't fit anymore
    Forr the cost of the catcam I might take the risk on it
    Feb 2011
    Down South
    what i will say is forget what people say and set to the correct 113 degrees as literature states, i was advised to set to 110 degees but went against it, tbh ive been in cars with both but prefer the snap power from the bb cat cam
    your choice boss but let us know what ya do
    As far as the C1J engine, a camshaft come with specific angles, AFAIK, if it's a Piper 285 at 110° then it should be set to 110°, a Piper 285 at 112°, set to 112°. Etc. With twin cams I presume you can play with that valve timing a bit.
    Aug 2010
    Cambridgeshire
    Advancing and retarding the cam with the 110-113 just moves the powerband down or upwards.
    im more interested if I'll gain a longer torque curve or reduce it with the bb cam
    Member Woznaldo's Avatar
    Canberra, Australia
    I've recently fitted a Cat Cams 325, but I'm still running the engine in so can't give any useful feedback just yet.
    Feb 2016
    If you do sell the cam, please could I have first dibs :-)
    Thanks
