any idea what would cause this odd oil pressure problem?
(standard oil pressure gauge) running 15w50 fully synthetic Fuchs oil.
from cold, reads just over '3', then as it warms up, the oil pressure rises to '4'.
which is where it stays until its up to temp.
then if you take the car for a 'good drive' then oil pressure drops back to just over '3', but when you rev it reads over '4' more like '5' - like it should do...
what would cause the low pressure when its cold?
dodgy oil pressure sender?
dodgy turbo core ? (- oil ways close up with heat?)
dodgy crank bearings ?
