Results 1 to 35 of 35
    Non-member ollyhock's Avatar
    STOCKTON
    What oil?
    Just about to service the car at the weekend
    What's generally regarded as the best oil and grade for the gtt
    Many thanks
    walsall
    Re: What oil?
    ive always used 10-40 myself and most brands
    Non-member haizyr5gtt's Avatar
    Nov 2008
    newport
    Re: What oil?
    i spoke 2 a mechanic at our local car accesory place (fast parts) he looked in a book and said 15/40 comma xt2000 semi synthetic is best suited.
    Apr 2002
    Re: What oil?
    Just use the cheapest semi-synth you can find.
    Non-member tobester's Avatar
    Bracknell
    Re: What oil?
    I use 5w40 fully synthetic Carlube Triple R and a bottle of greased lightning teflon treatment every oil change. Changed every 3000 miles.
    Non-member jure's Avatar
    Split (Croatia)
    Re: What oil?
    I use controversial Castrol RS Formula 10w60. Will try 5w50 due to my new turbo (GT series).
    Re: What oil?
    Halfords own 10-40 semi synthetic (in the green tub)
    Nov 2008
    Re: What oil?
    Quote Originally Posted by jure View Post
    Thats the same oil my M3 uses...£16 per litre, its like treacle!
    Split (Croatia)
    Re: What oil?
    For M3s and M5s Castrol TWS 10w60 is "prescribed" for keeping double Vanos in good shape. Do not know difference between RS and TWS only that second one is almost double in price.
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Re: What oil?
    Shell Helix Semi Syntectic 10 - 40 in my Renault 5 GT Turbos
    Duckhams Hypergrade Semi Syntectic 10 - 40 in my RS Turbos
    Castrol Edge Sport 10w - 60 in my RS Cosworths
    They all have different characteristics. I have tried mixing them round but that combination keeps the engines quite and well maintained.
    walsall
    Re: What oil?
    i must say i found this better then most ive used ?
    STOCKTON
    Re: What oil?
    thanks for the replys, i might consider changing my oil every 3k aswell so ill probably get away with the cheaper semi synthetic halfords as you say.
    anyway thanks for the advice
    Re: What oil?
    I use the cheapo comma semi synthetic 10/40. Its not so much the oil that's important its the regular changes.
    Non-member gttjames's Avatar
    Cambridge
    Re: What oil?
    10/40 here
    Non-member Mudslinger's Avatar
    Feb 2003
    Re: What oil?
    ive always used the mobil 1 motorsport stuff 15/50 next change ive been recomended to try Motul 300V competition 15W50 both pretty expensive oils
    Non-member sphinX's Avatar
    Feb 2005
    Telford
    Re: What oil?
    Same as mudslinger
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: What oil?
    Mar 2004
    Coventry
    Re: What oil?
    Miller CRS 10-60W was what I used to run in my silver C1J powered beastie
    Think tbh regular oil changes and prob any half decent semi-synth would be fine
    Guess it may depend a bit on spec of car / turbo to your choice also
    Non-member mightymanx's Avatar
    isle of man
    Re: What oil?
    Quote Originally Posted by haizyr5gtt View Post
    am after this oil but cant find it on my isle werd u get it?
    Feb 2009
    Herne Bay
    Re: What oil?
    Done nearly 100k using Mobil 1 fully-synth 0/40 changing every 6k
    Re: What oil?
    Oh dear god, not this one again! Comma aint the best for high temps or high rpms, it breaks down and ends up out of the exhaust (proved this at Motorscope rr day) I swapped to mobil super s 10/40 (Available from halfords on offer at the moment for 19 quid) and then ran the car at another rr day. Reved to 7800 rpm and maintained oil pressure and temp stability.
    Tried all the rest from bad to worse:
    Mobil 1 fully-synth 0/40-far too thin for a 1950's sloppy toleranced engine/rattled my lump.
    Miller CRS 10-60W- wrong grade/oil pressure was slightly higher tho.
    comma semi synthetic 10/40.- good for general use, no good when thrashing it.
    Shell Helix Semi Syntectic 10 - 40- difficult to get, expensive
    5w40 fully synthetic Carlube Triple R- Carlube stuff is generally remanufactured oil, i wouldn't use it. (Scource opie oil rep) and local motorfactors.
    Also used valvoline- that was good and smoothed the engine out 15/40 grade. only came in 4 litre tubs at the time so had no spare.
    Im using halfrauds in tyhe 225 engine at the moment, only because its dribbling out the bottom. After that, im going mobil super s.
    Non-member Frix's Avatar
    Re: What oil?
    taken from comma website, i use it with no problems!!!!
    Motorsport 5w-50
    Fully Synthetic 5w-50 Motor Oil specially formulated for Motorsport - Race Track, Road and Rally.
    Ideal for use in both petrol and diesel powered cars, go-karts, stock cars and dragsters.
    May also be used in engines using alcohol fuels.
    Offers enhanced anti wear protection when operating at extreme RPM.
    Increased detergency helps guard against high temperature deposit build up.
    Non-member Rusty's Avatar
    Edinburgh, Scotland
    Re: What oil?
    I've been using Tesco's sunflower oil, i wondered why it was running like a pig
    Didn't think it mattered what sort of oil you put in
    Re: What oil?
    Quote Originally Posted by Rusty View Post
    Apr 2002
    Re: What oil?
    Quote Originally Posted by Frix View Post
    Motorsport 5w-50
    Well they're hardly likely to say that their products are crap are they?
    Re: What oil?
    well they're hardly likely to falsely advertise!!
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: What oil?
    Really? You'd be surprised...
    Tipton
    Re: What oil?
    fuchs 15w50....
    Re: What oil?
    I've always used halfrauds 15/40 semi synth but every since I've been using the VNT and the cam I've been finding it starts to break down after sustaind trashing so I've switched to Mobil1 15/50 fully synth
    isle of man
    Re: What oil?
    so i tried a semi sythetic 10-40 oil .
    but i think i need something a bit thicker its a renault 5 gt turbo .
    143 tho miles so what oil would people recommend lol?
    Non-member royz's Avatar
    stockport
    Re: What oil?
    will 5w 30 do any damage.
    Non-member renault5gtboi's Avatar
    Dec 2008
    mirfield
    Re: What oil?
    use prolong oil!!! ither 10w-40 semi synthetic or 15w-40 semi synthetic
    check out thair tests they do when they put sand in a engine with prolong and then let out all the oil and rag the car around the track and the engine still works as a sort of lining is givern for extra performence check out the tests on youtube !! not cheep tho cost me £45 for 5 lts
    http://www.youtube.com/watch?v=oNSGG...x=0&playnext=1
    stockport
    Re: What oil?
    only reason i asked was i topped up using the stuff i put in my ford by accident and have noticed a burning oil smell since.
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    Re: What oil?
    Quote Originally Posted by royz View Post
    Was that because you spilt it everywhere while topping up?
    stockport
    Re: What oil?
    no. i always put some rags around when topping up as if i dont then i spill it. my own fault for being to lazy to use the funnel. ill keep a eye on it and if im stil not happy ill change the oil and filter over the weekend.
