Results 1 to 6 of 6
    Jan 2016
    carb
    can any one tell me if this carb is standard or its had any think done on it ive been told its had bigger jets
    Jan 2016
    Re: carb
    Non-member tubbyG's Avatar
    Dec 2010
    Re: carb
    Its near impossible to tell just from looking at it unfortunatley.
    Only way is to remove the carb and strip it down, then you can measure the jets with a set of micro drill bits
    Re: carb
    As said cant tell from jets, but the venturi is the right size.
    Non-member Fordy's Avatar
    Aug 2010
    Cambridgeshire
    Re: carb
    unless the venturi has been machined out grp a style....
    measure everything, verniers and micro drill bits will be your best friend
    Jan 2016
    Re: carb
    cheers for the info lads
