Results 1 to 4 of 4
    Wickford
    Speedo issues
    Hi all,
    Having some speedo issues, I have tried 2 sets of clocks and the same problem on both .
    The speedo works but seems very inaccurate , reads about half of my actual speed then doesn't move above about 40mph.
    Any clues,
    Thx
    Re: Speedo issues
    3 things:
    1. Clean the sensor that sits in the gearbox. It gets caked in crap.
    2. Check the connector mounted in the engine bay. Follow the grey speedo cable. Clean the connector or remove and solder the wires together.
    3. Make sure the connector at the clocks is sound.
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: Speedo issues
    just fit and use a sat nav.
    Its what i have been using the past few years.
    hassle free...
    Norwich
    Re: Speedo issues
    Quote Originally Posted by bigdavec1974 View Post
    Hi all,
    Any clues,
    Thx
    Take it you have tried the 3 usual things as above, just wondering if someone has fitted coloured dials and the speedo maybe out of calibration? either that or its getting a bad signal along the speedo cable itself. I would check the speedo pickup/sensor in the gearbox is cleab, should have a little clamp and 10mm bolt holding it in, is it pushed all the way in? Also check the 3 pin black connector near passenger suspension turret, may need a spray of contact cleaner. Finally the plug on the back of the speedo itself maybe corroded or insecure. I did find an issue with mine where the motor was stuck on rear of clocks which didnt help matters and just needed carefully removing, working backwards and forwards a few times then re-fitting. Might be worth trying another speedo that you know definitely works from another 5.
