Results 1 to 24 of 24
    Non-member Matty's Avatar
    Aug 2014
    Longwick, Bucks
    Standard shocks and other part numbers needed
    Does anyone know if standard GTT front shocks are still available from Renault? and if they are what they cost?
    Re: Standard shocks
    Yes they are still available. Think its close to around £100 - £120 for the pair as seeming that its £140 on ebay delivered.
    Aug 2014
    Longwick, Bucks
    Re: Standard shocks
    Ah great thanks. I saw the ones on EBay which made me think that they may be still available from renault direct (for less) I will give them a call tomorrow.
    Aug 2014
    Longwick, Bucks
    Re: Standard shocks
    I may aswell order some other parts at the same time. So does anyone know the part numbers of the rear quarter window catches, hinge rubbers seals, clips etc.. Basically all of the parts to fix the quarter windows in?
    Re: Standard shocks
    Check the dialogy pages I loaded up rubber seals not available now and rear window catches not sure on current price but was available little while ago one side more expensive that the other
    Aug 2014
    Longwick, Bucks
    Re: Standard shocks
    Ah no wonder the price has shot up on them they're now £50 for a set of the rubber seals!
    I had a look at that thread, I found the hinge part numbers but no seals? I know I have seen the part number somewhere on here though.
    Aug 2014
    Longwick, Bucks
    Re: Standard shocks
    Spot on thanks.
    Apr 2014
    Re: Standard shocks
    The catches were approx £15 the pair (11 & 4). Now NLA one side and that one side available is about £17.
    Only rear seals available fir £2 each. If you trim the hole, you can use these for all positions and re-use the plastic. Inners are still available.
    Aug 2014
    Longwick, Bucks
    Re: Standard shocks
    So are all the inner seals the same, front and back? Its mainly the outer seals that have perished and a couple of inner seals missing. I don't think the catches are too bad, but with the amount of play in the rubber seals, its not clamping the window up tight, and popping open.
    What's the part number for the rear outer seal? It doesn't seem to be listed in that drawing, part 15 says its a clamp?
    Apr 2014
    Re: Standard shocks
    Quote Originally Posted by Matty View Post
    You want part 15 for the rear.
    See if part 12 is still available. The kit isn't but the seal on it's own might be.
    You also want part 8 for front inners. I bought as a pack of ten. They're pennies from memory.
    Apr 2014
    Re: Standard shocks and other part numbers needed
    Mike and bob sell them for less than dealer prices.
    I've bought off of Mike but the part numbers are different to what the dealer told me. I need to double check what they're off.
    You're looking at approx £75 a corner from dealer.
    Re: Standard shocks
    Quote Originally Posted by Matt_S View Post
    I have enquired on that part, if in stock, shop might be getting a lot of those in
    Apr 2014
    Re: Standard shocks
    Awesome.
    Re: Standard shocks
    Aug 2014
    Longwick, Bucks
    Re: Standard shocks
    When will you know if you will be getting them? I phoned Renault today and they told me all of the window fitting parts are not in stock. And wanted £162 a corner for shocks.
    Re: Standard shocks
    They are working through the list at the moment, 300 part numbers might take a while
    Apr 2014
    Re: Standard shocks
    That's for a pair.
    I'll find my list later for you and clarify.
    Aug 2014
    Longwick, Bucks
    Re: Standard shocks
    Aug 2014
    Longwick, Bucks
    Re: Standard shocks
    That's for a pair.
    I asked if that was for a single shock and they said it was. To be honest they weren't very helpful at all, the guy I spoke to was trying to fob me off from the start, not even wanting to have a look without a chassis number. When I told him I had the part numbers there was a sigh on the end of the phone. I was tempted to go through all 20 odd parts I had on my list knowing that some were no longer available, just to piss him off for being so unhelpful, but thought better of it.
    Bought some from Mike now. I've got a busy weekend ahead of me now.
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Re: Standard shocks
    Thank you for your purchase and yes cheaper than Renault as I was able to buy in bulk so able to help on the price.
    Aug 2014
    Longwick, Bucks
    Re: Standard shocks
    Thanks For your help Mike.
    Re: Standard shocks
    Matty, you've got no time for hobbies. Get welding tube!
    Aug 2014
    Longwick, Bucks
    Re: Standard shocks
    Haha tell me about it, I've been working 70hr weeks for the past 6 months!
    I managed to convince the missus that I HAVE TO lower my car in the name of product research, to check the fitment of these exhausts.
    "....But I have to fit a bigger turbo and fuel inject it, to make sure everything still fits..." Will be the next line.
