Results 1 to 4 of 4
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    Drive shaft measuremen
    Hi all, anyone got a driveshaft sitting around that you could give me a measurement on? Need the diameter of where the shaft goes in the hub I.e the part an abs ring would sit on.
    Cheers
    Phil
    Re: Drive shaft measuremen
    Phil, I will have mine off soon if no one comes back in meantime Ill measure up
    Dec 2008
    tadworth
    Cheers mate it's a pain trying to find valver shafts and hubs with abs so I'm gonna see if I can fit abs rings on my shafts then try and mount brackets for speed sensors
    Non-member RussellT's Avatar
    Blackpool
    The ABS rings for a modern shaped Beetle fit the rear hubs and you can get reluctor rings from http://www.reluctorrings.com/
    Off the top of my head the Pug 206 89.5mm ones are the ones you need.
    R
