Results 1 to 5 of 5
    RC 1000cc injectors
    As per title I have set of 4 RC 1000cc injectors recently purchased of my friend whom is breaking his evo 5, these are a little overkill for my setup so selling them on.
    I just want what I paid so £140.00 + £10 recorded postage
    CheersJames
    Apr 2011
    Netherlands
    Re: RC 1000cc injectors
    Hi or low Z?
    Thé Evo 5?
    Hi or low Z?
    Thé Evo 5?
    Argh shit good point Arthur I better find out, removed from a modified EVO 5 that was running on MOTEC ecu, they are almost brand new
    OK the code on them is RC pl 4 1000
    Low ohm /Impedance/ resistance fuel injectors.
    - Electrical Connecter: Standard Square EV1
    - Type: Peak & Hold Japan O-Ring
    - Flow Rate CC's: 1000 CC's / MIN @ 43.5 PSI
    - Flow Rate LB's: 95 LBS / HR @ 43.5 PSI
    - Resistance: Low, 2.5 Ohms
    - Voltage: 8-15 Volts
    - Amperage: Peak 4.0 Amps / Hold 1.5 Amps
    - Pressure: Min 30 PSIG / Max 100 PSIG
    - Compatible Fuel Types: Pump Gas, Leaded Race Gas, Alcohol/Meth
    SOLD
