Results 1 to 8 of 8
    May 2003
    Haslemere, Surrey
    Article for central locking
    Am sure there was one, but can't find it. Searching seems to return very little of any use.
    Drivers door struggles to open, i need to turn the key to the max and then it just opens.
    Pulling the pin up does nothing, there is no movement (as is the same for trying to open the door from the inside). Think the culprit is a ceased central locking actuator, of which i reckon i have a spare.
    Re: Article for central locking
    May 2003
    Haslemere, Surrey
    Nah, not aftermarket. Just replacing what's there.
    Done it before but was just after a pic to see if my spare actuator is passenger or drivers.
    If you post a picture of the one you have here someone may know which side it is?
    Norwich
    I would also recommend removing the locking mechanism inside the door, remove central locking solenoid and soaking in diesel over night, toothbrush to clean it up, and re-grease and re-fit.
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    what dump the whole unit in diesel? works yeah?
    Norwich
    Yup, works a treat! Ice cream tub pop mechanism in and pour diesel in so its all covered and leave over night to soak, quick brush with a tooth brush, bit of grease and re-fit.
    THE BAT CAVE
