Results 1 to 6 of 6
    B18FT bottom pulley and water pump pulley
    I'm after a bottom pulley and water pump pulley for a B18FT, they are the pulley's the ribbed belt runs on
    Doesn't matter about condition as long as they are straight as they will be going off for powder coating
    Let me know if you have any, cash waiting
    Ireland Area Rep turbo ted's Avatar
    Ireland Co. Kilkenny
    Re: B18FT bottom pulley and water pump pulley
    Have f7p pulleys mark I think there the same
    I should have some F7p Pulleys from the fecked lump I had it's just a case of finding where I put them though
    F7P crank pulley is slightly smaller but will do the job for what I want, how you want for the crank and water pump pulley Rob?
    Cheers james, might be worth having spare. I need to mod one to accept a 36-1 trigger wheel so least I have another incase I bugger it up
    Picture of pulleys
    They are perfect Robbie, do you have the bolt for the crank pulley too?
    How much you want for them mate?
