Results 1 to 20 of 20
    Wickford
    Replacement copper fuel lines
    Hi all,
    I've been searching the forums and it's still unclear wether the copper fuel lines are 8mm id or od. I would have a measure up but have unfortunately mine are rubber
    If Ya gonna do summin do it properly !
    Cheers
    Feb 2012
    Nottingham
    Re: Replacement copper fuel lines
    Quote Originally Posted by bigdavec1974 View Post
    Hi all,
    Cheers
    Nip to your local plumbers shop bud it's 8mm cooper pipe you need about 10 meters about £15 easy todo just became full when closing the jubalee clips there really soft..
    Wickford
    Cheers
    They only have 10mm od , 8mm id, any good?
    They'll work fine
    Yes 8mm I/D is what you want. Some use 10mm for high powered cars.
    Member Woznaldo's Avatar
    Canberra, Australia
    I'm pretty sure it's 5/16" or 8mm OD, not ID.
    Woz,
    I would go for 3/8 OD with an internal of 8mm:
    http://www.ebay.co.uk/itm/3-8-OD-x-2...item2a1a32469f
    Wickford
    Cheers guys, went with the 8mm id. Ordered 20 feet , should be enough? Only 2 lines from pump to fpr?
    Ta
    Mar 2013
    Ta
    How did you get on with swapping your fuel lines. I got to do this next.
    Wickford
    Errrr not done it yet, next Saturday though. I'll keep u posted.
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    8 mm is the one!
    done mine about 8+ years ago.
    Practice the bends using a 30mm socket in an engineering vice.
    Use the old lines as a pattern.
    Wickford
    Bit of an issue there. The old lines were just replaced with rubber! Haha
    Mar 2013
    I was sure it's 8mm OD so will be good to see how you get on.
    Wickford
    What's the best way to join the rubber sections to the copper lines? Do the lines need flaring out at all? If so what's the best way?
    Cheers
    I just banged on some decent quality fuel hose - I didn't flare mine.
    Wickford
    So pretty much just squeeze the copper line inside the rubber section and seal with a fuel line clip/jubilee clip?
    Yep, that's what I've done. Obviously make sure the fuel hose is a good tight fit over the copper line.
    Solder a copper olive on and then heat the rubber hose until flexible enough to push over.
    Mar 2013
    How did you get on with this mate? Any difficulties?
    I plan to do this at the weekend so any tips would be helpful.
    Thanks
    Norwich
    This is on my list of jobs to do aswell!
