Results 1 to 11 of 11
    Feb 2011
    Down South
    What other driveshafts fit straight onto a 5
    had a quick look but couldnt find anything is there any driveshafts that have the abs ring that will fit straight into the 5 hub, looking for a valver but they are like rocking horse doo
    want to retain the original clocks for the 5 speedo with the jc5 box
    thx mick
    Apr 2011
    Netherlands
    Re: What other driveshafts fit straight onto a 5
    abs ring won't do you any good as the trigger pattern is different. Just buy a ring of Olly and fit it onto your existing driveshaft
    Feb 2011
    Down South
    already got ring from olly matey but it wont fit a 5 shaft thats why i asked matey
    Mick,
    It will if you weld it on. Just make sure it is aligned up.
    Mick,
    Exactly what I said the other eve then make a bracket of the hub to support the sensor
    Feb 2011
    Down South
    i must be deaf lol i didnt hear anything lol, is ollys bit weldable then?
    thx guys
    thx guys
    What's it made out of
    Ireland Co. Kilkenny
    Yes you can weld it as it mild steel or ask Oillie to make one with a small diameter ring to fit the gt shaft, the clio and gt shafts at the cv joint should be the same diameter
    Feb 2011
    Down South
    thx robbie ill remove shaft and see how the ring fits and then buzz some welds on it
    Mick, show us pics when you do.
    Feb 2011
    Down South
    of course sir ill tale a look this week then sort pickup after boss
