Results 1 to 9 of 9
    Mar 2015
    Massive list of parts needed. Any help appreciated!
    Hi All
    This is my first post here on RTOC. I've just purchased a Red GTT from a fellow member. I have quite a bit of work ahead of me in order to bring her back to her former glory and the enormity of the job is slowly starting to sink in... Below is a pretty daunting list of parts I need to try and locate. If anyone has any of the following standard parts in good condition please get in touch via PM
    -Standard dash
    -Phase 2 door cards front and back
    -Original ph2 Parcel shelf
    -Windscreen rubber blanking cap (the bit at the bottom of the windscreen? 35mm or 50mm)
    -Gear linkage return spring
    -Anti roll bar bushes polyurethane inner pair and outer pair
    -Rear engine mount
    -Exhaust rubbers x2
    -Battery clamp and bolt
    -New number plate lights
    -N/s outer window rubber
    -Rear opening window rubbers (the 3 plastic bits with the rubbers)
    -Driver's side door
    -Door roll pins x1 set
    -Driver's side check strap
    -Standard dial surround
    -Standard steering wheel
    -Standard heater dial control (the bits you twist)
    -Standard gear stick gator
    -Centre console blank (the one between the window switches)
    -Inner rear quarter panel plastics (the inner trims around the rear side windows)
    -Rear seat top half
    -Rear inner plastic trim (the one that covers the the bolts for boot)
    -Standard phase 2 driver's seat (rip to right bolster and bolster gone - is this fixable?)
    -Standard rear seats (rip at the top near parcel shelf - is this repairable?)
    -Standard top boost hose (as the one on it is cut with a t piece for the dump valve)
    -Standard Water hose from degassing chamber to the water pump
    -Standard Water hose from water pump to expansion tank
    -Standard bonnet
    -Standard roof
    -Roof lining
    Cheers
    Dan
    Re: Massive list of parts needed. Any help appreciated!
    Hi Dan,
    Welcome to the club, that is a fair list you have got
    -Gear linkage return spring - About £15 from Renault new
    -Anti roll bar bushes polyurethane inner pair and outer pair - cheap off rallydesign site
    -Rear engine mount - can get uprated off cgb on ebay for about £35 not sure on quality, else about £15 from motor factor
    -Exhaust rubbers x2 - £1 each from motor factors
    -New number plate lights - only set for sale £150 on ebay
    -N/s outer window rubber - New from Renault about £45
    -Rear opening window rubbers (the 3 plastic bits with the rubbers) - £35 off ebay and going up as no longer available from Renault
    -Standard gear stick gator - can still get from Renault new for about £60
    -Centre console blank (the one between the window switches) - Crazy money I don't know why
    Got a few of the smaller items but in process of sorting out all my spares so not in the position of saying price or pictures, I need to sort out time moving all the items about and organising it
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Hi Daniel, I have all the items you require and not far from you I am in Southampton. I will be up the unit this weekend.
    Thanks Mike
    May 2014
    Welcome to the club!
    Massive list of bits you have there, but all obtainable if you shop around. I will say though, make sure you do shop around a bit so you know whats out there & what prices things are. I was in a bit of a rush when I started restoring mine, so went off and blew a good 3 grand on parts when had I just waited I could have bought them loads cheaper from fellow enthusiasts.
    Non-member clarkey21's Avatar
    Jul 2010
    Mike will have it all mate, its like Aladdins cave there.
    North West Area Rep LukeRobbo's Avatar
    Nov 2008
    Cumbria
    I have some unused inner rollbar bushes I think they are the 23mm purple ones BY powerflex
    Mar 2015
    Hi Dan,
    Thanks for reply Big Foot, some very useful leads there! When you know what you have in your parts pile, please drop me a PM.
    Will do, ordered a gear gaiter myself, £55.78 to me that was
    Mar 2015
    BUMP.
    Go on people, have a poke about in the dark corners of your garage for a fellow GT owner in need!
