phase 2 gt turbo alloy intercooler
hi folks, looking for some suggestions on alloy intercoolers. looking to brighten up the engine bay, fairly standard, no huge boost to worry about. looking for standard size or even double capacity for standard fitment. What are you using and where can you get it?
cheers.
Re: phase 2 gt turbo alloy intercooler
Pace & forge did both an alloy stock sized intercooler & a double capacity one which is same sort of shape but twice as thick. Theres loads of cheap copies of these on ebay now, so id go for one of them.
Member
There's some good info in here:
https://www.rtoc.org/boards/showthread.php?t=4755
Like said above, a double capacity std mount intercooler will do the job and have extra capacity for any future mods. If you go for one of the cheap Chinese copies, make sure you have a good look at the pictures and check the quality of the welds. Some are better than others.
From memory, 'Majesty' do quite a good job. It's probably who I'd buy from.
