Clutch help
Bit of help/ advice needed.
Only bought my R5 last week and currently going through the process of getting it road worthy/ driveable.
The biting point on the clutch is about an inch from the top and the pedal itself is savage to the point I think it is trying to push my shin bone through my knee! Pair both of these things together and it makes it almost impossible to pull off.
Any ideas what it could be and what I could do to sort it?
Thanks.
Committee, Moderator
Re: Clutch help
Quite a common problem. It may be the clutch ratchet mechanism. Have a read here:
https://www.rtoc.org/boards/showthread.php?t=4732
It's likely you have the uprated volt clutch, quite a savage beast when used in the gt with no extension fork.
East Midlands Area Rep
Re: Clutch help
Sweet raider you have got there mate, welcome to the club.
Re: Clutch help
Thanks.
Have decided to go with the soft clutch conversion from scratch... Fun times ahead!
Moderator
South East Regional Rep
Re: Clutch help
Once the gearbox is separated from the block, the actual fitting of the extended clutch arm is easy.
I think there is a guide on here for removing the engine for a clutch change mate.
Good luck and any problems-ask away on here.
