Results 1 to 7 of 7
    Non-member Cr23g's Avatar
    Aberdeenshire
    fuel line plumbing
    hi folks.
    iv had a quick look in the files section etc but no joy. anyone tell me where the aux fuel/ transfer pump hoses go too. obv its connects to the bottom of the reserve fuel tank but where does the other hose go too? theres currently a longish hose connected to the pump with a t-piece on the end. thought id ask before i have to go and rip the tank off.
    thanks
    Non-member Corty's Avatar
    May 2014
    Barnstaple
    Re: fuel line plumbing
    at i guess id say up on the fuel sender in the car under the rear seats under the big black plate
    there are 3 hoses , ones to feed pump, one return , the other im guessing could be from the aux tank to the main tank ??
    dont quote that as gospel but it feels like theres a bunch of hosed t-pieces on top the tank and one lead back to there!
    I found Paul B's dialogy photobucket links from here in the articles section:
    https://www.rtoc.org/boards/showthread.php?t=372
    And then searched through to find the fuel setup. This is why RTOC is worth the money
    Assuming that actually gives you the answer you need
    Non-member jamie_clioGTT's Avatar
    Nov 2010
    Burntwood Staffs
    its answered questions i had trev, nice one !
    Paul B is a Renault and RTOC legend. Shame he's no longer around
    Aberdeenshire
    Yep solved it.
    When looking from the back of the car. One pipe goes to the left side connection on the sender. And the other pipe on the t piece feeds into the tank. Easy when you can see what your dealing with
