can anyone help my r5 runs for about 10 mins drives fine but then just cuts out like running out of fuel but will start up again please help
Sounds like fuel pump relay is playing about mate, quite a common fault.
take it apart and check for dry joints on the solder
Or could be the TDC lead mine did this before as it got too hot near the turbo and cracked the plastic casing around the wires causing them to short.
