Results 1 to 6 of 6
    Non-member clarkey21's Avatar
    Jul 2010
    horn, compressor
    Anyone had an issue with their horn ??? Mine is trying to work, the compressor makes a sort of horn noise, I guess it's not working correctly and pumping air out to the horn... Has anyone used a different compressor ????
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Re: horn, compressor
    Just get a cheap halfords jobbie and wire in. 😃
    A damn good spray of WD40 usually works. There's a pipe coming off the compressor that should be around the front headlight/intercooler area, spray it down that.
    Horn failure is notorious, excuse the pun. You have the compressor and the snail (horn unit). It's the horn snail that you want to spray some WD40 up. It's like clearing its throat.
    Dec 2012
    mine was dodgy after putting car back together..i just keep my hand pressed on button when I drive down lanes, its seemed to clear its self. works fine now!
    May 2014
    I just replaced mine with a generic twin horn one, nice and easy swap, plus sounds better!
