Results 1 to 6 of 6
    Jul 2014
    Leicestershire
    What turbo?
    Hi,
    My turbo gasket is leaking and I want some more power!
    What turbo spec would you recommend getting?
    I don't want lag, and want more punch 20-90 mph
    I currently have a 285 cam also.
    Any recommendations?
    Re: What turbo?
    Quote Originally Posted by Aterro View Post
    Hi,
    Tried and tested T25 with a .48 rear housing and 360degree thrust bearing! Should fully spool at 3500rpm and keep you going beyond 7500rpm.
    You could go for a t2/t25 hybrid and spool earlier but your cam wouldn't benefit greatly.
    Lots of info on past threads using the search function.
    Re: What turbo?
    Try CR turbos if you are wanting a quote.
    Jul 2014
    Leicestershire
    Re: What turbo?
    Hi, thanks!
    That's also the info I was after! As rang a few turbo companies and they aren't helpful at all!
    Regards
    Non-member danr5Gtt's Avatar
    Nov 2014
    Re: What turbo?
    Hi, thanks!
    Regards
    They are good, did mine in three days.
    Dec 2012
    Re: What turbo?
    that's the same power band I wanted .marky mark rebuilt my engine with 270 cam and t2/25 turbo, I went to crturbo ,absalutly brill, sent an old turbo. wasn't any good..was a brill company for advice and service. £620 delivered,still runnin in till my carb issue
