Results 1 to 5 of 5
    Feb 2012
    uphall west lothian
    wont start
    Alright folks my R5 has been sitting in my garage for a month and won't start, normally I disconnect the battery but this time I forgot so it was flat, with the battery changed I fully expected it to burst into life but it never, I can here the full pump and I have changed the plugs any ideas
    Re: wont start
    You actually got fuel going into the carb? sometimes it takes times for fuel to actually reach the carb if been stood for some time. If this happens i tend to remove the fuel pump relay and just bridge the red and white wire for a few min's to make sure good enough quantity
    has entered the carb bowl.
    you got spark?
    Non-member Matty's Avatar
    Aug 2014
    Longwick, Bucks
    Re: wont start
    Take the plugs out and see if they are wet with fuel, whilst they are out crank it over and see if you've got a spark.
    Feb 2012
    uphall west lothian
    Re: wont start
    Going to check for spark tomorrow, my garage isn't lit, the spark plugs were Brown
    Feb 2012
    uphall west lothian
    Re: wont start
    Ok it had a good spark and fuel but still wouldn't start, managed to bump start it and after a run it seems fine, so I'm putting it down to dampness, what's everyone's thoughts on this
