Results 1 to 18 of 18
    Non-member Magsimus's Avatar
    Mar 2014
    Clutch gone - is this going to hurt?
    Hey guys.
    Just driving the 5 back to my house and just as I got to the bottom of my road, the clutch suddenly broke and has gone all loose hanging there. I'm assuming the cable's snapped.
    If so, is this going to be an expensive fit regarding parts and labour?
    If not the cable, what else could it be.
    Proper fortunate it happened at the end of my road - been driving on motorways for the last hour - but still gutted as only picked it up from the garage last week after it passed its MOT
    Cheers.
    Dec 2012
    Re: Clutch gone - is this going to hurt?
    The cable is cheap enough on ebay and you can fit it in 5 to ten mins. Needs a second person on the crucial point to put to last bit over the gearbox thing. While the other person release tension on the pedal side by pulling the spring out a bit.
    Clutch cable and fan belt. Every R5 owner's essential kit to carry in the recess behind the side plastics in the boot
    Mar 2014
    Awesome, thanks. Will it be just as cheap/simple if it has the B18ft in it?
    Dec 2012
    Mine the b18ft too mate.
    Mar 2014
    Ah yeah, just saw your name - my old eyes aren't so good with these smart-telephone things, ha.
    Cheers chaps.
    Mar 2014
    Also, if I have the B18ft, will the standard 5GTT clutch cable suffice or do I need to get one from a Volvo etc?
    Cheers.
    Dec 2012
    Standard one will be fine.
    Mar 2014
    Another question - and it might be a daft one - but can I fix it from under the bonnet or will I have to get it up on ramps/jacks?
    Cheers.
    Quote Originally Posted by Magsimus View Post
    Cheers.
    It's easy job and even easier with car on a pair of axle stands mate
    burton on trent
    order a genuine cable.. dont mess about with cheaper ones
    Mar 2014
    Yeah, was going to grab one off CGB for about £40. Sound reasonable?
    Get one from Renault, CGB site comes to £58.78
    May 2014
    Ive lost track of the number of clutch cables ive fitted to mine over the years. Always fitted them myself. Not the easiest of jobs, but not too bad.
    Furthest away from home I had one snap was about 40miles. I just drove home with no clutch. Certainly helps develop your "traffic predicting" skills as to what cars up ahead are doing. Changing up & down a gear with no clutch is easy enough if you get the revs right - will slip straight in. Its when you want to stop, you have to knock it out of gear, stop, turn engine off, stick it in gear and start it up in gear to get it moving.
    Which reminds me I need to get a spare one myself!
    Norwich
    Defo worth getting a new genuine clutch cable for the 5, something else to add to the xmas list! .
    Mar 2014
    This one the right one? And will it work with the B18ft?
    http://renaultpartsdirect.co.uk/prod...tch-Cable.html
    Cheers.
    Cheers.
    That's the right part number. I cant see why it wont fit as its all in the same place with that engine.
    Mar 2014
    Great, nice one.
    Cheers.
