Results 1 to 12 of 12
    May 2014
    Avo coilovers
    Hi all I have just purchased avo coilovers they have two nuts on the top do I tighten the first nut as tight as I can then on too of that I put the donut then the top strut mount as there is not enough room for the bearings to fit hope some 1 can help as I'm sat here scratching ma head ha ha
    Re: Avo coilovers
    Quote Originally Posted by Webber View Post
    been a while since I have played with AVO's have you got the setup all bolted together the correct way?
    https://www.rtoc.org/files/Technical%...TZ%20setup.pdf
    May 2014
    Re: Avo coilovers
    They are as they came I have not touched them,I went on link you sent and looks like how they are
    May 2014
    Re: Avo coilovers
    Just. It sure weather I need to do the 1st nut up as tight as it will go and then do I just fit donut and top strut
    Re: Avo coilovers
    The diagram shows only one nut as far as I can see.
    If you have two nuts that doesn't seem correct. Can you take pics and upload them so we can see what's going on.
    May 2014
    Re: Avo coilovers
    Ok will do tomoro as they at garage they both have 2nuts but are not the same as the oe nut
    Non-member GTphil's Avatar
    Re: Avo coilovers
    Standard nuts are nylock ones. The two nuts your on about are to replace that one standard nut. The first does the job. The second locks the first in place as they are not nylock nuts and one would work loose over time otherwise.
    May 2014
    Re: Avo coilovers
    Ok brilliant thanks phil for info I'm finally gettin ma head around it all
    Re: Avo coilovers
    Get that second nut done up tight. Best way is to do it with the car on the ground so you have weight on the whole top mount assembly. I had to modify a 22mm step ring spanner so i could get it in and get a purchase on the nut.
    You can just get brutal with a windy gun on them whilst the shocks are off the car also or even using just a spanner if your brutal enough.
    May 2014
    Re: Avo coilovers
    Ok will go like a mad man on it with my windy gun didn't know I could do it that way so worked out well
    Re: Avo coilovers
    I just looked again at the diagram. Where the nut(s) are showing, they have one box but two nuts in it. Grrr. Far more obvious if they had drawn one line to each nut from the letters 'AS'.
    Apologies Webber for the duff response from me
    May 2014
    Re: Avo coilovers
    No worries mate I now know how the go to gether so all good thanks guys
