Results 1 to 6 of 6
    Non-member The Baron's Avatar
    Mar 2011
    Fitting Stack Water Temp Gauge
    Hi
    I was wondering if anyone can help with a small problem we have fitting an aftermarket Water Temp Gauge?
    We are fitting a STACK Water Temp Gauge to our 5 but are struggling to find an adaptor that will fit on the end of the Stack Sensor that then allows it to fit in the existing sensor housing in the engine?
    This is the gauge
    https://www.merlinmotorsport.co.uk/f...structions.pdf
    It says is has a 1/2"NPT mounting nut or 3/8" BSPT?
    Does anyone know anywhere that will sell the relevant adaptor we can fit on the end?
    Picture below
    Dartford
    Re: Fitting Stack Water Temp Gauge
    Personally I would remove the end plate on the head (opposite side to the water pump) and drill n tap that.
    Non-member Mattw's Avatar
    Jan 2010
    Burghfield common
    morning mate I think I got my adaptor from this site.
    http://www.demon-tweeks.co.uk/motors...pipes-adaptors
    Mar 2011
    Thanks all for your help
    Non-member j4ck-dw's Avatar
    Dec 2011
    alright mate ive got the exact same problem with the same gauge how did you get round it cheers
