Results 1 to 3 of 3
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Phase 2 suspension on a phase 1?
    Am I right in thinking that to fit coilovers for a phase 2 onto my red phase 1, all I need to swap are the top mounts or will I have to change the hub too?
    I'm hoping it's the former as I've got all the bits then.
    Thanks in advance
    Ross
    Re: Phase 2 suspension on a phase 1?
    The only thing you have to remember is not to mix/match the suspension components between phases. If using ph2 struts, use ph2 tops, if using ph1 struts, use ph1 tops!
    It doesn't matter what phase your car is as the turrets and hubs are the same, just ensure the suspension you fit is completely ph1 or completely ph2.
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Sweet. Thanks Trev.
    I've got spare ph2 top mounts so that'll convert the front end to ph2 then.
    Nice and easy then.
