Results 1 to 10 of 10
    Mar 2013
    scraping noise
    hi all been getting a catching scraping noise coming from drivers side rear when hitting bumps the car is lowerd quit a lot what could be the cause ?? maybe my rear shock has gone....
    Re: scraping noise
    Quote Originally Posted by KEV 5 GT View Post
    Youd know if rear shock was gone been there done that, sounds more like your catching arch
    Feb 2012
    Nottingham
    Re: scraping noise
    Check your rear tyres for marks on the edges it could be the bumper holders I used to get a straight line across mine.
    Mar 2013
    Re: scraping noise
    yh sounds like its catching sommot under there some where is it more than likely because its to low then I only noticed it when I put 15" alloys on I think
    Re: scraping noise
    What size tyre you using??
    Mar 2013
    Re: scraping noise
    ive got 195/50/r15 on
    Dec 2012
    Re: scraping noise
    the little bit of metal that sticks out where the bumper ends...mine does that same with a full car. as stated above should see where its rubbed the tyre away close to the side wall. think dropping down to 195 45 15s will help.
    Re: scraping noise
    Or just whipping out the offending useless metal with a grinder. Much cheaper!
    Re: scraping noise
    The reason you are now getting rubbing from going to the 15's is that your rolling radius is slightly bigger now as you are using a 50 profile tyre hence some scrubbage, either change to a 45 profile, or work out where catching, more than likely the rear bumper needs to be moved back to allow clearance. Mike and Mike aka R5MJH on here at the same issue with 16" alloys
    if it's the metal grind it back, but it will be the same issue peeps have with the 16" alloys and that will be rear bumper needs pushing back for clearance
    Re: scraping noise
    If it's the bumper it will wear it's own neat little path eventually
    On 195/50/15's, unless the wheel is over 7J wide, or a dodgy offset, the bumper shouldn't be too much of a problem.
