Results 1 to 7 of 7
    Non-member Corty's Avatar
    May 2014
    Barnstaple
    rpm signal / rpm pick up - Zeitronix Wide band for logging
    hi can someone point me in the right direction for the RPM signal wire
    i need to 'pinch' the signal that it sends to the rev counter
    wheres the best place to pick it up from?
    tried searching using different phrases but have given up now
    Im using Zeitronix ZT-2 wideband and will be logging tomorrow to check AFR against boost and RPM
    also hoping to install a eurotherm controller and fast acting temp probe (T/K series )to get ACT at two different points on the intake (after intercooler and at carb) to measure heat soak of the pipe work .
    Apr 2011
    Netherlands
    Re: rpm signal / rpm pick up - Zeitronix Wide band for logging
    Wire for the rev counter is on the aei, if you want to take it from the back of the dash it's pin 8 and 5 from the most right connector
    Be sure to check it with a Fluke though!
    May 2014
    Barnstaple
    humm thanks will go take a look
    no access to a fluke meter at the moment - bloody thing is in work lol? is one a signal and the other a ground?
    might have to take from low side of coil instead........
    Apr 2011
    Netherlands
    They're connected to eachother, don't ask me why!
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Thin grey/brown wire to the fuel pump relay
    May 2014
    Barnstaple
    "Thin grey/brown wire to the fuel pump relay "
    im guessing this is the rpm signal wire that activates the high speed/full load of the fuel pump after a stated RPM eg 2000 rpm ???
    is this chap located in the passenger footwell?
    still waiting for my haynes manual to arrive !!
    I need i the wiring diagrams!
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Quote Originally Posted by Corty View Post
    No, the fuel pump relay uses the tach signal to decide if the engine is running or not, and so to energise the pump or not.
    Yes, passenger footwell, long looking relay, 5 wires I think;
    thick red = battery live
    thick white = fuel pump live
    thin black = ground
    thin yellow = ignition live
    thin brown/grey = tacho
