Results 1 to 5 of 5
    Dec 2013
    Removing windows
    I am having a respray at the moment.
    Just wondered how hard it is to get the windscreen and rear window out?
    Are they both bonded in?
    Also am I likely to need some new seals after when fitting back in, wheres best place to get them if so
    cheers for help guys!
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    Re: Removing windows
    Rear and the sides are easy, the front is bonded in and can be a pain, not cheap for the proper windscreen fitting.
    As above, the rear screen is a cinch to get out/in.
    The front might be better getting a place to refit it. You can probably remove it yourself with some cheese wire etc.
    Non-member Jimmy5's Avatar
    Oct 2010
    As has been mentioned front is a pain to get out. I smashed mine. I know paul gt turbo got a guy from Barnsley to take screen out of his white phase 2.
    If you do smash glass make sure you don't damage the middle seal as new renault screen comes with inner and outer seals.
    Rear screen should pull out easily. If you need help give me a shout.
    Dec 2013
    Thanks guys
    gonna get someone to take windscreen out and refit then!
