Results 1 to 12 of 12
    Jul 2012
    need some help getting my car started
    good evening, need some help or advice on what to try
    since rebuilding the car it hasn't been started
    did have the car turning over, and was getting a spark to the plugs but
    left it for the last 2 month and when i went to try and turn it over today i got nothing, not even a click from the starter, have 12v at the starter and it's getting 12v to the little wire on the starter
    just i don't know what to try first, any help please
    Committee Member
    Social Media
    LeeR5GTT's Avatar
    Eat, Sleep, Boost
    Re: need some help getting my car started
    Check your earths dude. You could use a jump lead to make an earth too just incase
    Jul 2012
    i tried this, even fitted a new earth cable from the engine to the chassis
    Feb 2012
    Nottingham
    Quote Originally Posted by lee View Post
    And the one to the block from the drivers side?
    Jul 2012
    that's the one i changed
    May 2014
    You say your getting 12v to the starter but the starters not doing anything? Have you tried hitting it with a hammer. Ive got through several starters on my 5, it seems to be down to their location right near the exhaust.
    I used to use a long chisel and from the top to tap the starter solenoid and that sorted things for a while but eventually a new starter was in order.
    Jul 2012
    i hope it's not the starter as it's only about 6 months old and it's had no use as the car hasn't been started only turned over a few time.
    Jul 2012
    i did try the tapping/ hitting but still no joy, will try attaching an earth cable to one of the fixing screws in the hope that i have a bad earth
    Jan 2014
    Can you smell burning around the starter?
    Non-member Hoolio's Avatar
    Wallingford
    And you know the battery is fully charged?
    Jul 2012
    will check for burning smell tomorrow,
    The car was on a battery booster when i was trying to start
