Results 1 to 2 of 2
    Non-member mike's r5's Avatar
    High Wycombe
    Boost problem please help
    Hi guys, having problems with my boost, the car was set up for 18psi in October after about 500miles I boosted it up at a set of lights and the actuator arm popped of the turbo which is when I parked it up for the winter, over the winter I changed the boost gauge and carb elbow and put actuator arm back on but now I only had 13psi which I thought was the new boost gauge, then recently about 2000miles later have only got 8psi so started to investigate.
    I have checked intercooler pipes visually for splits and have tightened all jubilee clips
    Changed the carb elbow back to standard
    Tried a different boost gauge
    Pumped actuator up to 20psi and held fine
    None of this has fixed the problem
    Is there anything else I can check.
    Can someone tell me how to pressure test the intercooler and pipes
    Any help much appreciated.
    Re: Boost problem please help
    O-ring on the carb top?
    Split in the boost hoses that only show up under pressure?
    I can't remember how people have pressurised the boost circuit to check the hoses but a quick search should help. Otherwise you could fit someone else's hoses temporarily and give it a run out.
