Results 1 to 8 of 8
    Non-member Jamraid5tt's Avatar
    Apr 2013
    C1J Rebuild
    How hard is it to strip down and rebuild a c1j engine and has any body got any advice or diagrams before I start??
    Re: C1J Rebuild
    Pretty easy as engines go. Grab a Haynes, there's loads of pictures in there.
    Non-member GTphil's Avatar
    Re: C1J Rebuild
    The dizzy timing and cam timing are sometimes a little difficult to get your head round if it's the first time you have done it. A little easier if it's all staying o.e. If your putting a hot cam in and an adjustable cam pully you will want to read the camshaft article in the articles section of the site. Some really good info and guides on how to do it.
    Up until a few years ago i had never had a bash at building any engine and the Haynes and this site was pretty much all i needed.
    If you have built engines before then the c1j is pretty simple in mechanical terms and should be a breeze.
    What are you building the engine for? o.e power or more?
    Apr 2013
    Re: C1J Rebuild
    Just going to keep it oe so hope this makes it all abit simple . Never built an engine before but I'm sure it's worth having a go. Think I have all the new parts I need.
    Non-member Jonny5's Avatar
    Sleaford
    Re: C1J Rebuild
    Fairly easy and very rewarding
    Re: C1J Rebuild
    Find a good machine shop that will do cash jobs
    If you get stuck with anything just post up on here, there's always someone willing to help.
    Definatly best to use new parts
    Apr 2013
    Re: C1J Rebuild
    Need piston liner set just wondering where to get them from and a fairly good price...
    Re: C1J Rebuild
    Try Mike,
    https://www.rtoc.org/boards/member.php?u=380
    if it's available he can get it
