as above , after taking the boss off and undoing the centre nut does the wheel just prize off, im sure this is the case but mine is not budging and im getting paranoid..
this is not a trick question...come on....
BASH IT!
Yea wip the cover thing off, then undo the centre nut and "prize it off" or cant you just undo the allen bolts?
just be careful not to smash your teeth out!!!
will need a bit of stick to get it off, is just on a splined shaft held on only by the nut, would recommend putting the nut on a turn or so to stop it smacking you in the face when it does come flyin off
Yeh, leave the nut on finger tight towards the end of the thread, so you don't break your nose when it finally comes loose, and then really go for it.. Left to right, front to back.. Pull like a mofo on crack!
all done cheers lads..., grr come on whats next..., new wheel looks good , has heaps of grip and i cut the rreno boss down to size for that oe touch...., cheers lads!!!!!
Matty, empty your PM inbox !
