Results 1 to 16 of 16
    Jun 2014
    High Wycombe
    Renault 5 gt turbo complete bottom end
    I'm looking for a complete running bottom end for renault 5 gt turbo as my piston ring have gone and have been told it's easier just changing the bottom end, thanks
    Dec 2004
    Aylesbury
    Re: Renault 5 gt turbo complete bottom end
    Its a days work to change the rings mate
    Jun 2014
    High Wycombe
    I'm no good with stuff like that tho! I wish I could do it my self as I would rather keep that bottom end! But Michael was saying it would just be easier changing the bottom end!
    Agree with Mark fix what you got or get a local member whom knows his stuff to help or do it
    Dec 2004
    Aylesbury
    Quote Originally Posted by Dawsie View Post
    If you want guidence/help doing it i don't mind, as you say if you want to keep your bottom end its prob better way. Trouble with used bottom ends you can never tell what they really like till they run
    Jun 2010
    sw london
    wink wink pay mark a days money job done
    Jun 2014
    High Wycombe
    Lol, How much would you charge mark?? The only thing is the car is at mine and has no tax and MOT so can't drive it to you!
    Jun 2014
    High Wycombe
    I think me and micheal are going to give it a go, can we leave the engine in and take the head off and sump off?
    Feb 2011
    Down South
    yep you can do it that way mate just make sure you lock the liners in place though
    Dec 2004
    Aylesbury
    Thats right mate, as mentioned keep liners held down and do one piston at a time
    If get stuck i'm not far away
    Jun 2014
    High Wycombe
    Thanks lads, we have now taken the head off and sprayed WD40 in the bores, should this soak through? Cheers
    Feb 2012
    Nottingham
    Bud contact mark he's the man that can and close your lucky everyone travels to get marks help.. It will be cheaper in the end. And done right 1st time
    Jun 2014
    High Wycombe
    Thanks for everyone's help, we took the pistons out tonight and I had a cracked one which would be causing my problems!!!
    Dec 2004
    Aylesbury
    If you get a nice used one,. fit new rings, hone the liners. put back together it'll be back to normal
    Least you found what it was
    Jun 2014
    High Wycombe
    Thanks mark, I take it all pistons are the same as mine have a black head and the one I'm going to buy has a silver one? Cheers
    Dec 2004
    Aylesbury
    All standard pistons will be the same
    The black colouring will probably be the build up of soot mate
