Results 1 to 26 of 26
    Non-member nath17t's Avatar
    middle bit
    clutch help
    will any uprated cluth of a 5gtt fit my volvo 1.7 turbo engine?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: clutch help
    Quote Originally Posted by nath17t View Post
    you will need to know if you have a 200mm or 215mm clutch. only the correct one will fit on your flywheel.
    middle bit
    Re: clutch help
    its the 200 what is the best clutch for the power im running its got the ecu mod and is running 14psi
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: clutch help
    the standard 215mm valeo will work fine for that mate.
    middle bit
    Re: clutch help
    thats to big thow int it
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: clutch help
    sorry, typo. the standard in either case will work OK at 14psi.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: clutch help
    and by standard, I mean the GTT 'uprated' thing which is the same thing ofcourse.
    middle bit
    Re: clutch help
    the thing is that is the one i had in and it lasted about 2 weeks
    middle bit
    Re: clutch help
    could you recommend a uprated one ?
    middle bit
    Re: clutch help
    Oxfordshire
    Re: clutch help
    what's the betting that you've already tried that one
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: clutch help
    you could find a 215mm flywheel and use the later clutch. the 200mm should have worked fine for you, if it lasted 2weeks then something killed it. you won't be making staggering torque at 14psi.
    maybe its gotten contaminated, I used to kill paddle plates on one particular gearbox because the input shaft seal was leaking, always a layer of gearbox oil and crud inside the bellhousing and on the clutch cover. I bet it would see a normal clutch off just as quickly.
    middle bit
    Re: clutch help
    will the one from k-tec be any good then ?
    Oxfordshire
    Re: clutch help
    I thought you said you'd tried it and it lasted 2 weeks?
    middle bit
    Re: clutch help
    is the one from k-tec just the valeo one like
    Dec 2004
    Aylesbury
    Re: clutch help
    Yes the one from K-Tec is the Valeo one that GSF sell, no difference just there sticker on it
    middle bit
    Re: clutch help
    ho is gsf?
    Oxfordshire
    Re: clutch help
    which valeo did you fit? Do you have a part number?
    stevenage
    Re: clutch help
    http://www.gsfcarparts.com/
    German, swedish, & french
    btw, I didnt read the thread and take it was meant to say "who". Just trying to be helpful lol
    middle bit
    Re: clutch help
    dont have the part no is there more than one type?
    Dec 2004
    Aylesbury
    Re: clutch help
    From GSF you can get a Sach's one and a Valeo one which is from the volvo, the volvo has 2 types which Scoff mentioned, a 200mm one and a 215mm (the 200mm is the uprated gt turbo one).
    middle bit
    Re: clutch help
    how much is it?
    middle bit
    Re: clutch help
    what about helix clutchs? does any one know how much torque the volvo engine puts out with 14psi?
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: clutch help
    https://secure.gsfcarparts.com/shop/results.asp
    try using there search function for prices part numbers ect its alot easier
    Dec 2004
    Aylesbury
    Re: clutch help
    I'm using a 200mm Helix paddle clutch in my volvo engine and i'll be pushing alot of power/torque through mine so i might have to upgrade, but for your spec it should be fine. I've known a few volvo engines run a fair bit of boost on the 200mm paddle and it has held up, but at 14psi i can't see why a standard volvo one won't hold up.
    middle bit
    Re: clutch help
    thanks for your help what kind of power are u running throw yours
