Results 1 to 16 of 16
    Dec 2012
    clutch cable
    anyone got a clutch cable in the northwest? melted mine on my exhaust....cant get a new one till tuesday. i can pick up.
    Dec 2012
    Re: clutch cable
    weird one checked cable its not snapped but when i press the clutch pedal no tension in it. just drops to the floor. how do you reset the clutch pedal ratchet?
    Feb 2011
    Down South
    Re: clutch cable
    Quote Originally Posted by B18ftMOJO5 View Post
    remove plastic stopper near top of pedal then ratchet the clutch and replace stopper
    Dec 2012
    Re: clutch cable
    if my pedal sits really high does that mean i havent got a stopper on there. just check gear box side there is a few mm play on that side. could it be the cable has stretched and its not engaging the ratchet.
    Dec 2004
    Aylesbury
    Re: clutch cable
    Sure its not snapped at the top on the pedal?
    Dec 2012
    Re: clutch cable
    found a semi circle piece of platic in to footwell...is that the stopper?
    Feb 2011
    Down South
    Re: clutch cable
    sounds like ratchet has snapped boss or somethings gone adrift the stopper is a small piece of plastic maybe 20x15 mm
    maybe the rod bar that holds it in place has come slighty out worth checking boss first
    Dec 2012
    Re: clutch cable
    i think that may be it semi circular black piece of plastic?
    Feb 2011
    Down South
    Re: clutch cable
    that is known as the ratchet or clutch quadrant check the bar aint moved boss or the ratchet is broken matey
    Dec 2012
    Re: clutch cable
    thanks mate ill try that see how i go if not have to order a new pedal and try that.
    Feb 2011
    Down South
    Re: clutch cable
    there most be a picture somewhere but id remove the seat for easier access, there easy to do, the rod passes between the pedal box throo pedal then back into pedal box with a clip at both ends matey, the cable goes around the outside top part of pedal then around the quadrant, check cable nipples not broke either mate, any probs mate give us a shout
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    Re: clutch cable
    This should be of some help buddy.
    Dec 2012
    Re: clutch cable
    found my problem i think the cable sheath touched the exhaust because id removed my heatshield as it was catching the accelerator cable. i think it got stuck and i pressed the pedal pulling the end bit through. New cable tuesday it is then.
    Dec 2012
    Re: clutch cable
    got to love rtoc members...big thanks to Devlish Dave, coming to drop me off a clutch cable sometime this morning...Legend.
    Dec 2012
    Re: clutch cable
    sorted i now have a clutch again
    Dec 2012
    Re: clutch cable
    and its gone again lol....defo need a new one.
