Results 1 to 36 of 36
    Non-member *MrB*'s Avatar
    Mar 2013
    Cornwall/Devon Border
    RAIDER for sale
    For sale
    Renault 5 GT Turbo RAIDER –
    1990/91 H
    93997 Miles
    Fantastic history, I've not personally seen one with better history, all original books, service history, loads of old MOT's etc. Massive folder full of receipts and parts renewed/replaced.
    Running 18psi and pulls nicely. Was set up by Tony at GT turbo spares.
    Hpi clear.
    Mot til September and tax til October.
    Engine
    Completely Rebuilt in 2007
    Painted & Cleaned Block & Head
    K-Tec Pistons & Liners
    Oil Pump Overhaul
    New Timing Chain & Tensionerr
    K-Tec Uprated Headgasket
    K-Tec Uprated Head Bolts
    K-Tec Bottom End Gasket Set
    K-Tec Sump Seal Set
    Uprated Valve Springs
    Uprated Valve Stem Oil Seals
    Genuine Crank Spacer
    New Water Pump
    New Starter Motor
    Stainless Steel Turbo Gaskets
    Uprated Inlet/Exhaust Manifold Gaskets
    Uprated Stud & Nuts
    New Rocker Cover Nuts & Washers
    Genuine Clutch Cable
    New Throttle Cable
    New Driveshafts
    Genuine Thermostat
    Black Distributor Cap & New Arm
    New Engine Wiring Loom
    Various Replacement Sensors Fitted
    New Engine Mounts
    Engine Modifications;
    K-Tec KTR180 Hybrid turbo
    K-Tec High Pressure Fuel Pump
    K-Tec Metal Fuel Filter
    K-Tec Stainless 2 & 1/2” Downpipe With Lambda Boss
    Gas Flowed & Enlarged Turbo Elbow
    New GT Turbo Spares Re-Engineered Carb
    Re-Jetted for 17psi
    Adjustable Cam Sprocket
    ITG Maxogen Air Filter
    Prospeed Stainless Exhaust with 3” Outward Rolled Tip
    Cup Mod to Actuator Circuit
    Mocal Oil Cooler With T/Stat & Braided Lines
    GT Tuning Double Capacity Intercooler
    Uprated HT Leads
    Boost Controller
    Engine Dressing
    Full Samco Hose Set
    Matching Vacuum Hoses
    K-Tec Lobster Back Carb Elbow
    Pro Alloy Header Tank
    GT Tuning Top Water Hose Insert
    Chrome Rocker Cover
    Chrome Cylinder Head Plate
    Chrome Engine Lifting Eye
    Chrome Alternator Adjustment Arm
    Chrome Cam Chain Cover
    Chrome Lower Pulley
    Chrome Alternator Fixing Bracket
    Mikalor Heavy Duty Clamps
    GT Tuning Oil Separator Pot
    GT Tuning Swirl Pot
    GT Tuning Ninja Oil Cap
    GT Tuning Radiator Cover Plate
    GT Tuning Turbo Heatshield
    Polished Horn Pump
    Brackets Painted/Powdercoated/Cleaned
    Replacement Strut Top Covers
    Body Work;
    Original Raider – Restored in 2007/2008
    New Genuine Renault Parts including Wings
    New Headlights (Lucas)
    New Indicators
    New Yellow Fog Lights
    New Washer Jets
    Rear Wiper Removed & Grommeted
    OE Grille
    New OE Sideskirt Seals
    New Door Check Straps
    Suspension, Brakes & wheels;
    GT Tuning Big Brake Fit – Front
    GT Tuning Brake Kit – Rear
    Painted Callipers
    GT Tuning AVO Coilovers
    Goodridge Braided Hoses
    OZ Replica Wheels with195/45-15 Toyo Proxes (~1000 Miles)
    Interior;
    Custom Trimmed OE Seats
    Matching Door Cards
    Matching Cluster Binnacle
    Replacement OE Replica Dials from RTOC
    Polished Steering Wheel Boss
    Centre Triple Gauge Pod
    Stack Boost Gauge
    AEM Wideband Kit
    Stack Voltmeter
    GT Tuning Short Shift Kit
    Clifford Concept 650 Cat1 Alarm & Immobiliser.
    Philips CD player
    Couple of small jobs to do - top seal on fuel tank around sender, leaks when brimmed. Speedo head lazy but odometer works fine.
    Drives superb, looks superb. No nasty surprises. Was thoroughly checked out by Tony at GT turbo Spares including compression test and checked top to bottom. Following my visit there I've fitted new rear wheel bearings, handbrake cables and sorted some electrical gremlins.
    £4500.00
    PM for more info / telephone number.
    Mar 2013
    Re: RAIDER for sale
    Mar 2013
    Re: RAIDER for sale
    Dec 2012
    Re: RAIDER for sale
    May have someone for this. Ill email him for you.
    Re: RAIDER for sale
    Probably the best raider out there!
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    Re: RAIDER for sale
    Awesome car, awesome seats! Mistake selling it buddy as this is one fine example.
    Willing to put money on this being sold within a week easy!
    Mar 2013
    Re: RAIDER for sale
    Cheers guys, if it sells it sells, if not I'll keep it but just don't have the time to enjoy it sadly
    Mar 2013
    Re: RAIDER for sale
    Project thread and some more pics here;
    https://www.rtoc.org/boards/showthread.php?t=34782
    Mar 2013
    Re: RAIDER for sale
    Sold
    I wish the new owner all the best and he has a cracking Raider.
    Aug 2013
    Re: RAIDER for sale
    Well done mate hope it's going to a good home
    May 2013
    Re: RAIDER for sale
    Chris got to say a big thanks car was on the button and as described cheers mate...
    leaving as it is just want to add the rear Raider window sticker if any one can help with this?
    Dec 2012
    Re: RAIDER for sale
    Well done mate hope the new owner becomes a member on here.
    Re: RAIDER for sale
    Quote Originally Posted by B18ftMOJO5 View Post
    Did you not see the post from jaf
    Non-member JP Racing's Avatar
    Apr 2009
    Ely
    Re: RAIDER for sale
    You never know dale he might join and if he does he will get all the help and advice he will ever need
    if anyone has an image or a original raider sticker for the rear window i could have it replicated if its something the owners want
    Re: RAIDER for sale
    I got pictures of each letter and the whole lot, trying to find the dimensions of it, just no time to sort it all out. too much chasing to do, though did just get loads of Raider door badges done again
    Re: RAIDER for sale
    Found the letter sizes as well now. Just need the total length which I might have to measure again.
    Apr 2009
    Ely
    Re: RAIDER for sale
    cool if you dont mind sending stuff i could have some made if its ok with you
    Re: RAIDER for sale
    PM your email address and I will send over all the info I got to hand so far.
    Re: RAIDER for sale
    Dec 2012
    Re: RAIDER for sale
    My bad i should have gone to specsavers lol.
    Mar 2013
    Re: RAIDER for sale
    Glad your pleased Jaf, I knew you would be. Enjoy buddy and look after it
    Jan 2014
    Re: RAIDER for sale
    Gutted - I remember that car being for sale before and missing i then!
    So much want!
    May 2014
    Re: RAIDER for sale
    Hi there
    Hope you are well? Just seeing if you have managed to sell this yet? Let me know - if not, do you have any other photos?
    Mar 2002
    East Sussex
    Re: RAIDER for sale
    Quote Originally Posted by Steve Hawkins View Post
    Hi there
    It sold within 48 hours buddy, great example to.
    May 2013
    Re: RAIDER for sale
    1990/91 H
    94000 Miles
    Hpi clear.
    Mot
    Engine
    Oil Pump Overhaul
    K-Tec Sump Seal Set
    New Water Pump
    New Starter Motor
    Uprated Stud & Nuts
    New Throttle Cable
    New Driveshafts
    Genuine Thermostat
    New Engine Mounts
    Re-Jetted for 17psi
    Uprated HT Leads
    Boost Controller
    Engine Dressing
    Full Samco Hose Set
    Chrome Rocker Cover
    Chrome Lower Pulley
    GT Tuning Swirl Pot
    Polished Horn Pump
    Body Work;
    New Indicators
    New Washer Jets
    OE Grille
    Painted Callipers
    Interior;
    Matching Door Cards
    Stack Boost Gauge
    AEM Wideband Kit
    Stack Voltmeter
    Philips CD player
    Custom Interior, Will try to get more picture but not sure when as car stored in garage
    Not enough Use Possible Sale, the car has had thousands spent
    £6000
    Re: RAIDER for sale
    This is slightly confusing. Is this a new advert? It appears to be an exact copy of the original advert text tagged onto the bottom of the old for sale thread?
    So effectively the car is for sale again at a different price from a different owner?
    May 2013
    Re: RAIDER for sale
    The car is up for sale and is still the same as it was when I bought it from the previous owner. I have put it on ebay for £6750 but if someone is interested from this club I would let it go for no less than £5500, otherwise will keep it stored and use in summer.
    It's a unique car with lots spent on it, just want to see what interest it gets.
    Re: RAIDER for sale
    Thanks for the clarification. There are some members looking specifically for a good low mileage Raider.
    May 2014
    Re: RAIDER for sale
    Not a bad return on an 8 month investment.
    It looks like a nice car, so good luck with the sale!
    Jul 2014
    Re: RAIDER for sale
    if anyone wanted the car they would have paid £4000 for it then, what makes you think anyone would bust out another £1000 minimum for something they passed up...
    Sell it on eBay, more mugs on there, add that it's one of 1000 limited raiders and only 6 on the road today, it came with extra bhp from the factory and each raider was pi55ed on by virgins..
    All lies but ebay buyers and idiots lap it up...
    If I listed this on eBay, the BullSh2t would be out in force..
    Moderator
    South East Regional Rep
    LiamR's Avatar
    Dec 1998
    Medway, kent
    Re: RAIDER for sale
    In all honesty Jaf, I'd of started a new 'for sale' ad. As everyone can see the max price you paid for it and now the higher price that you want mate.
    The prices of 5s are undoubtedly increasing, just not sure by that much. But good luck with the sale. ( I'd buy it off of you at the original price )
    Norwich
    Re: RAIDER for sale
    Stunning raider, prices are certainly on the up, good luck with the sale. .
    Apr 2014
    Re: RAIDER for sale
    Quote Originally Posted by FlashbangGtt View Post
    That's not really fair to the seller. It's not his fault that the value has gone up!
    If say, he'd bought a bunch of Gold and the value went up, would you be saying that he should be selling at the price that he bought it at?
    I didn't think so!
    It's a nice car. Assuming it's as clean underneath as elsewhere. If it was OE, it would be worth more.
    Good luck with the sale.
    May 2013
    Re: RAIDER for sale
    Thanks for the positive comments
    I have had 2 offers already but a little low, I think I will keep it as I wont be able to buy again, I will reconsider selling once my Tungsten grey is finished that one will be the one worth £12k plus only done 47000 miles, low owners, totally original
    May 2013
    Re: RAIDER for sale
    Re: RAIDER for sale
    If you do decide to put it back up for sale, use the original advert's text but make sure you start a new for sale thread. I'm closing this one
