Results 1 to 2 of 2
    Nov 2012
    Slovenia
    Radiator fan problem, again...
    Hello,
    well, have radiator fan problem. Thought it was becuse some dodgy wires so I make some new conectors and now it looks ok. As I test if the fan will kick in by shorting conector with screwdriver, I can hear relay click but fan doesnt turn on. So I messure with volt meter on the fan conector and there in no electricaty. Does relay click if they are broken?
    thanks,
    Martin
    Re: Radiator fan problem, again...
    Try another relay, swap with the horn or perc fan. Also stick 12v on the fan and see if it works, the wiring can break off at the motor.
