Results 1 to 12 of 12
    Feb 2011
    Down South
    Steering knock fecking me off
    hi all, right ive put all mikes suspension on the car and refitted the drive shaft,
    befor i took it to bits it had a knock but i put it down to all the play in the donuts and other suspension parts, i put it back on and briefly drove it tonight and the knocks still there im going to check tom but has anyone else had this??
    theres no play in the struts themselves its had new track rod ends and bottom swivels about 500 miles ago and the uj dont seem to have play and also it only seems to do it when on the ground tbh theres not much it could be maybe the rack or the rack track rod, does the bottom part of the column in the car every go???
    also the steering wheel has no play in the car in or out so i presume the steering column bush is ok
    thanx in advance mick
    Non-member mingblus3's Avatar
    Apr 2013
    Re: Steering knock fecking me off
    I know it sounds daft but could it possibly be something else. Like the water bottle moving around in the bracket. I've always thought the rubber strap with a load of water in the bottle would do a poor job of supporting it.
    Oct 2012
    A
    The plastic cover on the bottom of the rack sometimes comes loose. Mine did and knocked like a slag when I turned.
    Feb 2011
    Down South
    thanx tc its not got one so its not that
    ill check bottle 2morrow si but i can hear something when i rock the wheel like they do on the mot, theres no play thou
    Apr 2013
    probably not the water bottle then if you can do it while stationary. I hate any sort of knocks or squeaks and they are usually quite hard to pin down. What about the driveshafts. Not that I know anything about drive shafts but could be one could be on it's way out.
    Feb 2011
    Down South
    ok had a quick look today and its got play in the rack somewhere, looks like it could be the ns track rod but not 100% im going to get it in the air tom and remove the steering rack gaitors to see whats goin on also im not ruling the uj totally out until i check it tom, hopefully this will be the end of it and then mot but tbh mikes got my subaru for a week and i need the seicento so hes not that worried anywayz pmsl
    Fingers crossed that rear diff on you poobaru holds out with him power sliding it
    Feb 2011
    Down South
    ive told him jim if he brakes it, hes bought it
    kin tosser he is
    lucky i aint done all the upgrades yet, running 340 to him is wrapping it up
    kin tosser he is
    I am sure he is looking after it
    Feb 2011
    Down South
    ok so i put the car in the air today and theres no play but ive found the fault
    its the steering rack 100% feels like theres a tooth missing on the cog
    id like a recon part anyone got any ideas thanx as always mick
    Feb 2011
    Down South
    just ordered a refurbed rack from cgb not bad £95 delivered off there site, all new parts except the out part bob recons
    Feb 2011
    Down South
    was the rack this time so sorted
