Results 1 to 3 of 3
    Non-member wilton_warrior's Avatar
    Apr 2011
    f7p conversion parts needed
    hey. myself and blue are under taking the valver route for the wee 5's. im going turbo n blue is hitting N/A (for now) so any parts you all may have spare lying about and or know where to get hold of be magico. I used james5 for f7p conversion list but took away the parts I know we both will have as we both got clio ph1 donors and or already aquired.
    Phase 1 16v Low or High Boost fast chips chip for F7p conversion for Phase 1 ECU
    One way valve for brake system
    One way valve for crankcase breather to inlet 8mm id
    K-Tec or BBPT Clio 1 down pipe
    GTX front engine metal mount
    GTX or Volvo upper and lower alternator mounts
    R21 2 bar map sensor
    R21 turbo injectors
    soft pedal conversion now have. cheers coops
    relevant intake/boost hoses for chargecooler set up
    and any other parts which will assist us in this be decent. monies ready cheers
    Feb 2009
    Walsall
    Re: f7p conversion parts needed
    Mighy be able to help you with gtx mount.. Think i had 2 and i made one myself il see next weekend when i go down to my car
    Apr 2011
    ah decent. hopefully i got one from james5. however blue mackay is doing same con and requires on. ill sent him a message n let him know you may have one
