Results 1 to 6 of 6
    Non-member boostjunky's Avatar
    Nov 2008
    London
    The mahooosive b18ft oil filter
    The b18ft oil filter seems to be the biggest I've seen on any car, does anyone know if it's possible to replace it with (for example) one of the slimmer oil filters from the Clio 172/182 and mk1 16v?
    Thinking purely from the perspective of freeing up additional space in the engine bay.
    Non-member Benjibrady's Avatar
    Jun 2011
    Bruton
    Re: The mahooosive b18ft oil filter
    Quote Originally Posted by boostjunky View Post
    Im using a standard C1j oil filter on my 'ft
    Quote Originally Posted by Benjibrady View Post
    Was just going to say use a std GTT oil filter.
    Nov 2008
    London
    Cheers lads.
    I know an oil filter is an oil filter at the end of the day, but wasnt sure if they had some kind of valve internally etc hence the incredible size.
    Ben
    Cheers lads.
    Ben
    They do have a pressure valve in you will be fine with the GTT filter on a B18ft I used the GTT purflux filter on my f4r, f7p conversions without any pressure issue's
    Nov 2008
    London
    Sweet thanks bro, need to free up as much space in their as I can
