Results 1 to 4 of 4
    Non-member Gttnutter's Avatar
    Oct 2005
    Amersham
    Clio 16v non start
    So i've got a clio to work on which the story goes something like this: the lambda sensor was ripped out of the exhaust just beorer the plug so i've wired it back up correctly and plugged it back in and i'm not getting any spark nor fuel but its cranking fine. so i'm going to take the ecu out and try it on mine as i know my wiring etc is fine and is a perfect runner
    now do these ecu's have an immobliser or would it be a straight forward swap?
    and any other thoughts on what could be the problem?
    mine is a K plate and this one is an M so hoping there is no diffrerence in the ecu etc?
    Re: Clio 16v non start
    the ecus should be a straight swap i had this problem on my brother valver and it was the ecu becuase they are in the scuttle water tends to get into them try the tdc sensor aswell rhys
    Oct 2005
    Amersham
    yep when the rain stops i'll get out there...also where is the fuse for the ecu?
    Oct 2005
    Amersham
    Problem solved....blown fuse
